still_bill
OX66 used parts for sale. Some great deals here!
Rock-bottom firm prices, but will discount for multiple purchases.
All parts in good working order (unless noted). All parts (except Top Cowling) are from 1999 Yamaha SWS 250 HP.
All parts should fit 1999-2001 225HP and 250HP models. Many parts also will fit 1997- 2003 various models.
Check www.Boats.net for price comparison and fitment (see http://www.boats.net/parts/search/Yamaha/Outboard/1999/S250TXRX/parts.html)
For large parts, pickup in Gainesville, FL. Contact by e-mail for purchases (Cash, M/O PayPal preferred) [email protected]
See this link for photos (in same order as list): www.hells-canyon.com/ox66.htm
CDI Ignition Box (computer) - $325 (free shipping)
Flywheel Cover - $25 (free shipping)
Dual Engine Tie Bar Link Kit with hardware NEW! - $35 (plus actual shipping)
Intake Cover/ Air Baffle Silencer – ($35 – free shipping)
Intake Throttle Body, Fuel Rail, Injectors, Linkage ($100 plus actual shipping)
Resistor with Cover ($35 free shipping).
Oil Pump with hoses ($35 free shipping)
Mid-section cowling valence (2 pieces) ($25 plus shipping)
CDI Bracket with 4 ignition coils -$50 plus shipping.
Misc. Parts and wire harness (contact for prices)
Ignition Rectifier with cover ($50 free shipping)
Starter solenoid, fuse block, relay ($20 each with free shipping)
Heads (with water jacket covers attached) ($50 each or 2/$75 plus actual shipping)
Exhaust Baffle Cover ($30 free shipping)
Plastic Electrical Covers (2) ($25 for both – free shipping)
Gear Shift Rod Assembly – ($25 plus actual shipping)
Reed Box Intake Assembly (slight rust on stops – can be cleaned) ($50 plus shipping)
Crankcase Half ($50 plus shipping)
Trim Cylinders/Pump/Reservoir (no motor, may need piston end seals) ($60 + shipping)
Zinc Anodes (3 tabs, 1 bracket) ($30 all, free shipping)
Cowl latches and cables (partial set) ($30 free shipping)
Bolts and Hardware (all 3 boxes) ( $100 plus shipping)
Pistons and Rods (1 bad piston) ($100 all, plus shipping)
Crankshaft ($100 plus shipping)
Flywheel ($60 + shipping)
Lower Unit (broken prop shaft – should be good inside, but not guaranteed, case good, not locked-up, good waterpump) ($125 – local pickup only)
Midsection with bracket ($100 – local pickup only)
Lower Cowl Pan ($40 plus shipping)
Upper Cowling (2001 225SWS) ($100 –local pickup only)
Everything above $600 (local pickup only)
