Does the grey wire from the coil go directly into the 10 point connector, which travels from there to the tach, or does it go to the timing/sensor in the dist then to the 10 point connector and then to the tack?
I have cleaned and checked all the connections and i'm thinking the timing sensor must not be working , you indicated not likely but possible, would the boat still run ok with this sensor not working? others are saying the signal goes directly from the coil ,thru the 10 point connector directly to the tack???
If its direct is there any reason i cant run a new wire from the neg side of the coil to the tack ?
In some if not most cases, there should be two grey wires at the neg side of the coil. Is this true on your motor?
One goes to the timing module and the other goes to the 10 pin connector.
If that is not the case then the three way connection of the grey wires may be in the harness. Not typically.
One grey wire goes to the large connector. from there it goes to the dash. At the dash there may be another connector. Did you look and see if this is so?
My boat has a second connector.
Confirm if you have or have not a second connector.
If you do then check connections if not, now do a ohms test on the wire.
Ignition OFF!!!!!
Remove grey wire form tach, connect to one meter lead.
Make a long jumper and disconnect the grey wire at the coil neg. connect the long ire to the ring terminal of the grey wire.
Connect the long wire to other ohm meter lead.
It should be 0 ohms..........if you meter has a beep selection just use that.
That will tell you if the wire is good from the gage to the coil.
DO the basics first. Conform the wiring is good.
To answer your question about the timing module, if the grey wire feeding the module was not connected or broken the motor would not advance the timing.
The pulse from the negative side of the coil, the same pulse that the tach reads would be missing and the module would not know so to speak that the motor was running therefor would not advance the timing and the motor would run like crap.
Also one other thing, Make sure the ground wire going to the tachometer is a good ground connection. No ground no tach.
