Upper unit gear set
bobbya
"Hi,
I have a 1991 searay
"Hi,
I have a 1991 searay 4.3 200. It has a generation two outdrive and i did not have enough oil in the outdrive so it burned up. I took the outdrive off and can see that the upper unit gear set has burned up. Is there anyway i can replace just those two gears without special tools and extensive knowledge? I see the gears online for about $250. I would love to get away with just replacing them. Is this realistic?
And how would i know the lower unit doesnt have metal flakes in it and is still good to use? when i drained the oil, no flakes came out but when i open the top of the upper unit to look at the gears, you can see metal everywhere.
Can i put an SEI upper unit on the merc lower?
Thanks for the help!"
"Also, i can not separate my u
"Also, i can not separate my upper and lower units because the allen screw holding the little fin on is stripped. Any thoughts on how to get it off?
Thanks in advance!!"
"Let a professional do the wor
"Let a professional do the work. An SEI top will fit to the LU but the LU should be looked at. A new SEI top will be about the same or less to rebuild your damaged top. Get an estimate for the entire job as a repair and as a replacement top.
To get the allen screw out, soak it w/PB Blaster. Then get the allen wrench set that has a beveled end on it which allows it to fit in a little deeper and also work offset."
"There arent too many ways to
"There arent too many ways to remove it. Can try a metric allen wrench and tap it in, other than that the zinc is drilled and removed in sections to get to the bolt part and is cut away."
