"Ok so went down and went thro
"Ok so went down and went through everything again and here is what found.
-Backflushed oil coolers - I think but hard to tell, that the cooler on the hotter engine is flowing less water, but not by much, did get some zinc pieces out.
-Removed end caps from heat exchanger and found some scale/shell and the remainder of the old zinc inside. Cleaned that and was able to see the tubes looked clean.
- Tightened belt on pump
Took boat out for short 20 min run and stayed cooler, basically stayed below 170 until got above 3400rpm then went just above 170. I did notice it was still 5-10 degrees hotter than other engine but better than was. I did confirm all these temps with the temp gun and still about 5-10 more across various parts of motor and exhaust.
So in doing this also noticed that the coolant portion of the heat exchanger was about 15 degrees hotter than other motor and so were all parts where coolant ran through from what could tell. SO what might cause this? Coolant system flushed and changed one year ago. Does this sound like a flow problem or something else? Where should I start? Should I try changingn the thermostat?
Thaanks for all the responses and input.
RM"
RM"
