"We tore the engine down this
"We tore the engine down this morning and found the upper half to be new! The heads were in excellent condition as were the valves. The head gaskets were not blown nor wore. The rockers were all in excellent condition and adjusted well. It was obvious to all that some one had been inside this engine before us. It has thick rubber valve cover gaskets which are not standard. The cylinders are all smooth and no carbon anywhere. The pistons are in excellent shape but they are stamped with numbers. Not just 1 then 2 but they all have a bunch of numbers on them? Its good news that nothing needs machined but why doesn't it rev up? BTW, when pulling off the heads some water got into the cylinders and it was there all day and did not go down at all. This shows me that the cylinder walls and piston rings are good and tight. We are replacing the solenoid/starter, fuel pump, oil pump and pan gasket. We are going to check the cam clearances and the timing chain so we'll replace the timing cover gasket. The carb was just rebuilt as was the dist. and a new module. In essence I'll have a remanufactured engine plus all new parts that normally don't come with a remanufactured engine, but it is a mystery why it will not rev up. Any suggestions please post them. Thank you all, Bob"
