Unstable rpm when trolling
Bryan Gould
I have a 9.9 4-stroke, runs and starts great but I have a hard time maintaining a constant trolling rpm. It iether climbs or drops after a bit of time. Any suggestions?
Not sure which generation 9,9 that you have, but the typical causes of this kind of problem are...
Thermostat stuck open...and engine running too cold.
Partially clogged idle passage in carburetor
Improperly set idle mixture.
Poor compression
Valves out of adjustment.
Bad spark plug
Bad fuel and/or water in fuel.
There are a few things it could be.
Mike
Poor compression
Bad spark plug
Mike
Thanks I'll check some of those things out.
