Unknown wire coming from my 2000 50 HP Johnson
spirit87
"I've got a 16 foot alumin
"I've got a 16 foot aluminum boat that was rescued from a family member who lost their home in hurricane Katrina. It has a 2000 model 50 HP Johnson that's in pristine condition. Only problem, I can't get it to run. There's a pair of wires coming out of the engine that has been cut off. One that's black, and one that's tan with a black stripe. There is a tab on it that says, "Note Do Not Connect Wires To Battery. Internal Tank Circuit Will Be Damaged." Can somebody please advise on the purpose of this wire? Is it the reason I can't get it to run? Thanks for any help!"
These are the oil tank sender
These are the oil tank sender wires. They send a signal to the warning system when the oil level in the tank is low. They will not keep the engine from running.
"Thanks Rick,
If I'm pre
"Thanks Rick,
If I'm pre-mixing my fuel oil,I don't need to worry about even having that wire coming off my engine, right?
Thanks!"
"That's right, but you wil
"That's right, but you will want to unplug the VRO pump connector. This will keep the alarm from sounding when the processor in the pump realizes there is no oil in the fuel, once it does start."
"There is a round four wire ha
"There is a round four wire harness coming out of the VRO pump. Simply unplug the connector, it is about 6" from the pump body."
