eric_jacobson
"My 2000 5.0 EFI MerCruiser wi
"My 2000 5.0 EFI MerCruiser with an Alpha I outdrive engine warning alarm sounds after boat is used for 1 to 2 hours. It only sounds when at low RPMs. All gauges read normal, and all fluid levels are good. Alarm stops when boat accelerates and then starts again when I slow down. I had the boat checked by mechanic. They originally thought it was the water pump but when checked the boat was operating within normal ranges. They could not recreate alarm condition, but thought it was a bad oil pressure sender. They did not have the part. I bought oil pressure sender and replaced it myself. Next time out engine alarm sounded again. Had boat checked by mechanic. Boat was operating at normal ranges. They could not recreate alarm, but thought it was low gear oil. They added and said that was it. Third time out same thing. Does anyone have any idea what could cause this kind of alarm at low RPMs but not at higher RPMs?"
