Hello all,
I just purchased a 2005 Monterey with a 5.0 & Alpha outdrive. It ran like a champ when I purchased it, though as a preventative measure I went ahead and replaced the risers, spacers, manifolds, and thermostat as well as other maintenance items like the fluids, separator, etc.. Now that everything is back together I'm noticing that the risers are cooling unevenly. Typically the left riser will be cool to the touch while the right riser is too hot to touch. What I have noticed is that when I pinch the feed hose to the cool left riser, the right riser will then cool down and vice versa. Both will be cool for a few minutes and then one will heat up. It looks to me like water is fed from the thermostat housing via a t-valve with two check balls (one going to each riser). The check balls inside the t-valve move freely.
Any ideas where I can look next?
