Bestfishes
I have a DT50 (1983) with an exhaust leak under the engine block. After removing some cover plates I have discovered that to remove the engine block I must undo 8 bolts from below. They don't want to turn and heating them with a flame torch doesn't look easy as the threaded parts of some of the bolts are unseen below the block.
Should I just snap the bolts and lift the block and try and remove the stuck parts of the thread later or is there another option I can explore without taking it to the marine mechanic?
Regards....Craig
Regards....Craig
