I have been reading the forum for a few weeks and really appreciate all the good advice. I have a 1985 Californian with twin 454 Crusaders (model 350). Fresh water cooled with around 650 hours. The starboard side runs 15-20 degrees hotter at cruise (190-200 on dash gauges, vs 160-170 for port). I just bought an IR thermometer to check the temps more accurately next time I go out. I get some steam out the exhaust, but it seems about the same on both sides. I will also check the impeller before I go out again.
I suspect the U cooler based on forum advice. I unscrewed the zinc and only 1/4 inch came out. Rest is still stuck in the hole (probe hits metal immediately). I put the cap back on and it would not tighten much (threads are mangled). It now leaks continuously (about 1 drop per second). Should I buy a new cooler or try to repair this one? Curiously, the port looks newer (flat bottom design with horizontal zinc). The port side has a 45 degree twist at the exit elbow, which makes it hard to route the hose back to the heat exchanger. Should I go with the older stlye (90 degree twist, straight route to HX), or newer one? I don't understand why it was replaced with poor fitting newer style, unless there is some advantage.
Thanks in advance!
Thanks in advance!
