I bought a 60 hp Johnson motor, Model # J60TLCEA, last fall. It had not been used for about 2 years. First thing I did was to install new impeller in water pump. Old impeller was intact. Motor started and ran well with muffs. A good stream of water came thru tell-tale tube before winterizing. When I started motor this spring (early), water came from tell-tale briefly, then stopped completely. Checked for clogged tell-tale hose -- none! Removed fitting coming from head, to which tell-tale hose is attached, then started motor. No water seems to be reaching the head. The water intake on lower unit seems to be clear of debris, etc.
Is there any way to backflush the motor without removing lower unit (removing the shift connector rod is next to impossible due to its location)? Any suggestions?
