Txrt 225 yamaha smokes after start up
markt
have a 95 225 with 700 hrs. st
have a 95 225 with 700 hrs. starts and runs fine. after warmup if shut off it smokes alot.wondering if fuel problem or? thanks
the plugs are a little black b
the plugs are a little black but not fouled. wondering if fuel regulator might be shot or leaking
"yes.starts fine when cold goe
"yes.starts fine when cold goes to high idle,after about 5mins slows down not much smoke.if you shut off when warm then restart big cloud of smoke.has new fuel pumps.compression is fine."
injected.it runs fine i don&#3
injected.it runs fine i don't like the amount of smoke after startup.it would seem it is getting to oil or fuel on startup.
"try pumping the fuel bulb whi
"try pumping the fuel bulb while running
if it is smoking afterstart up, got to be fuel or oil"
