Pictures, Please.
I agree with Kim. See if it holds first.If it aint leaking it dont need to be fixed just keep an eye on the gasket if you go to try and push the gasket in you may be opening a can of worms.
I'm thinking the yellow starter cable will stay for a while,
At least give this Yellow cable a RED shrink tube identification band and especially at the MBSS "common" terminal, and/or the battery bank "Positive" terminal.
Not necessarily so much for YOU... but for someone else in the future.
As said earlier... yellow is now synonymous with DC Negatives.
That said.... yellow with red stripe is often used for the starter motor solenoid "magnetic" triggering circuit....... or IOW, from the key switch "S" terminal to the solenoid "S" terminal.
I'm not happy about the prospect of pulling the engine to install a new pan gasket. What would have caused that gasket to bulge out like that?
That looks like one of the silicone gaskets. These do not require any sealant. Sealant will lubricate the gasket, and may cause it to slip/slide while being squeezed.
Any chance I could just loosen it and tuck it back in?
I'd sooner see you loosen and drop the pan a bit, clean the area from all oil film, and fill this void with a good RTV type silicone gasket maker product.
If it holds... simply trim the excess... and no one will be the wiser.![]()
Ayuh,.... I disagree 'bout the oil pan gasket,.... It don't need changin',...
It's a multi-fit gasket,.... as it'll fit Both the Pre-'79 pans, 'n the post-'79 pans, up to '86, when the rear main seal changed,...
In 1979, the dipstick moved from the port-side of the block, to the starboard-side,...
I'm attracted to you.
You turn me on?
