el_pescador
Silver Medal Contributor
"A few tips:
1) Have th
"A few tips:
1) Have the boat surveyed by a professional surveyor.
2) Have a professional mechanic test engines (general condition, compression, etc) and drives if the surveyor does not provide that service.
3) The engines are Volvo marinized car engines. They will respond well if you take care of them, but they can be finicky. They have dual carbs that need to be properly synchronized. The aluminum heads can have corrosion problems around #3 and # 4 exhaust ports, but that's not a big deal (it can be repaired or the heads can be replaced). The timing gears are prone to pitting and eventually can lead to the timing belt failing. The good news is the engine valves are non interference, so if the belt breaks the valves won't be damaged.
For a boat of that size, I would have preferred a single engine setup (350, 454 or even a diesel). However, there is no reason why you cannot get out of it a nice family boat if the hull, wiring and power plant are in good condition.
Again, the most important thing is to get the boat surveyed and tested."
1) Have th
"A few tips:
