"Hi All,
I'm new here a
"Hi All,
I'm new here and seen quite a bit of info that is quite good, I'm hoping that someone has some suggestions for my issue.
I have a Bertram 25 with twin mercruiser 3.0LX motors, one is an 86 and the other is an 07. My issue is with the 07 motor.
This started last year when after a 2hr run to the fishing grounds the engine died and started back up again instantly. The engine would run for about 1/2 hr and then all of the sudden die instantly, always restarting after a few minutes. The issue progressed to a point where sometimes the engine would start and sometimes it wouldn't, every time it wouldn't start because of no spark.
I replaced the plugs, wires, cap, rotor, then coil, and finally the ignition module and got a few runs in to save the season.
This spring, the engine wouldn't start and following advice I found here I swapped the wire with the diode that connects the coil to the distributor and got the engine running.
I noticed that when the engine got hot, the tach would start bouncing and if I went over 3000rpm I would hear electrical discharge and the engine running rough. It got to the point where I ordered another ignition module.
The new ignition module lasted 4 trips before the tach started bouncing and I'm back in the same place. Last trip out I was coming home and The tach started bouncing so I took some ice from the cooler and held it on the bottom of the distributor and cooled down the ignition module and it got the engine running properly. A few minutes later when hot again the engine was running rough and the tach bouncing.
I've had 2 different mechanics look at the engine and neither have a clue.
I'm thinking of constructing a custom heat sink and attatching it to the bottom of the distributor to dissapate the heat or potentially getting a lower temp thermostat.
Anyone have some suggestions?"
I'm new here a
"Hi All,
