Twin DF150 2009
carlnap
I just bought a new boat with
I just bought a new boat with twin 150 Suzuki. I'm coming up on my 20hrs service. What should this consist of and how much should I pay??
new oil
oil filter
gear lube
new oil
oil filter
gear lube
adjust idle speed
pull prop and grease
tighten all nuts
inspect fuel lines
Hey Carl every dealer is diffe
Hey Carl every dealer is different. We give the 20hr service for free when you a buy a engine from us. The average cost per engine would depend on the dealers labor rate. We charge around 225-275 dollars per engine parts and labor. It takes us about two hours per engine but I do more than most would do. Most of the service is inspection and everyone dose it a little different.
Here is what we do.
visual inspection of engine
chk all engine grounds and connections
compression chk
spark test
remove fuel filter for fuel sample replace filter if needed
inspect all linkages
pull prop look for fisihing line grease torque and install new cotter pin
change engine oil and filter install new drain plug gasket torque to spec
change gear oil inspect drain screw gaskets
grease all zirk fittings
chk tnt fluid level
chk hyd steering fluid level if you have
chk your control cables and adjustments wot ect
load test clean and tighten all battery connections top off water and apply corrosion spray
clear your 20 hr oil change reminder
re-chk engine oil level
treat engine surface with Buster protective spray
grease side and oil pan cover bolts
set-up file on SDS for future service and
for any warranty problems that may come-up
I hope this helps. I think I got it all. I perform this service myself right along side my tech's so I know how long it takes. If your dealer his good work ethics it shouldn't take more than a couple of hours per engine barring no problems.
