Hello, have a 1970's boat with twin AQ130 with Aquamatic 250 drives.The boat is quite in an original but very good shape - a bit of a wheeler dealers style - if you know the UK tv series.
But, does anyone know how to adjust the trim fins in a dual engine setting?
Service manual says nothing about twin engine setup in the 250 manual, but in Aquamatic 280 manual (page 140) there is quite much info - One should set the left fin 5 degrees and right 30 fin degrees to the port side.
In addition it says that in a twin installation one should have the toe-out angle set - 9/16" to 1" (15-25mm) so that the ends of the drive are that much closer.
Does all this apply to 250 or not - they are a bit different of course, or do you have any other comments?'
Jukka
Jukka
