Twin 40 HP Yamaha question
bama
I tested the boat out for the first time since I bought it. I added a voltmeter to it and the motor connected to it reads 16.2 at WOT. I can't find anywhere that sells a voltage regulator for these motors(1985 ELTK 40 hp). So, can I put both motors on the same battery and disconnect the lighting coil wires going to the rectifier so I am only running one rectifier to charge a battery and then use the other battery as a stand alone unit...no motor connection, for my sensitive electronics?
If I can do this, can I still get my tach to work if I just disconnect the wires heading to the rectifier?
OR....can someone help me figure a way to add a voltage regulator. I am not afraid of learning a new skill, have access to plate aluminum and know how to TIG and solder.
I am not running a maintenance free battery. I can add water, but am worried about the Helix 7 I have getting fried. That being said, I was using a 1977 Johnson 55 for 3 years, probably in blissful ignorance of the overcharging issue. My last starting battery lasted 8 years.
Thanks.
Why do you feel the need for a regulator? The current output from your lighting coil is so low that 16.2 volts is not going to harm your battery.
Or is the problem that 16.2 volts is causing your electronics to shut down?
Almost any motorcycle permanent magnet generator rectifier/regulator should work. For instance
https://www.google.com/search?q=mot...ILQ&biw=1396&bih=657#spd=12616426964993993863
https://www.ebay.com/p/6660123-SPI-01-154-16-Rectifier-Voltage-Regulator/1439885554?iid=312452681103
I am worried that I would damage my electronics. They have never shut down or acted strangely, but until now, I never realized the older engines have no voltage regulator. Electricity is my weakest area of understanding as to how too many volts would affect my more expensive(at least to me) electronics. If it won't affect it, then I won't do anything. These are my first yamahas, but also my newest motors in my boating/fishing career. :)
I'm not sure i would add a regulator for 16V, but it is higher than the normal 14-14.5 charging voltage of larger systems
Your electronics should specific an allowable voltage range, for example, my Lowrance GPS/Fishfinder allows 10-17 VDC. If you are outside of what your equipment is rated for, I would consider the regulator.
Terry
Terry
I took it out today and it went over 17 at WOT. I will check my Helix 7 voltage range. I don't mind putting in a regulator, but mine has a lot more wires than the links posted by boscoe. I am mostly worried about messing up and breaking something else. I never worried before I installed a voltmeter in the dash on this boat and I think it was possible that my last motor was putting out a lot of volts. Sometimes, knowing about something makes it more likely to break. :)
I looked it up and it takes from 10-20V input power. So, I think I am safe. Whew! I just need to make sure I don't buy maintenance free batteries when I need to buy batteries.
Your lighting coil has but two wires. Both green. Two wires into the rectifier/regulator and two wires (one black, one red) out.
Yes, but what about the other wires on the rectifier? I would assume I leave the one that sends the AC signal to the tach plugged in from the lighting coil. But, there are several wires coming out of my rectifier that I don't know what they do. I am assuming this is the rectifier. Rectifier.jpg
I have had exactly the same concerns about my 2007 40 XWT. WOT sees about 16volts on my dash voltmeter, confirmed with an external meter. That really is too much for most electronics and globes etc. I found a service manual so that I could do some checks and was a bit surprised to see that the specs quote the following voltages. Cranking 3.5 Volts, 1500 rpm 13 Volts, 3500 rpm 30 volts. This is out of the rectifier, being the black and red wires. I know lots about 4stroke/car systems and electronics is my profession, but still coming up to speed on 2 strokes and magnetos. These voltages just seem crazy and i am surprised that any electronics survive. The comment about maintenance free batteries is valid, they will be damaged by these voltages compared to ones that you can simply top up with water. I plan to do some more research on this but will appreciate comments and input to enlighten me as to how we get away (and we certainly seem to) with such voltages. It seems very odd to me that the output is not regulated.
Another thing to consider especially if considering fitting a regulator as suggested by bama ,is that 12 volts is also incorrect for battery charging. During charging up to around 14.5 volts is fine (this figure is less for a sealed maintenance free version, a battery will sit at around 12.6 when fully charged. Many of the ebay regulators simply quote the output at 12 volts, this is not really going to get the job done.
Sorry about multiple posts, but I am researching this on the fly. I see that there are many threads over a lot of years on this topic and the bottom line is that certain of the yamaha models( I am new to the brand) have rectifiers only and no regulator. Is there typically a plug in yamaha rectifier/regulator that can solve this problem or do we need to go aftermarket? I am also getting the impression that for most of the time we just get away with it. Shame to find out that we cannot always get away with it when some electronics is fried.
What service manual and what page of the service manual lists the voltages you are mentioning? I suspect that you are confusing a charge coil output voltage with a lighting coil output voltage.
The regulators are nominally stated as 12 volts. Part of a 12 volt system. The R/R actually output nominally 14.5 ~ 16 volts.
There is more to electricity than voltage. There is also current. In the smaller Yams even though the voltage appears to be high the current is minuscule. Not enough to harm a lead acid battery. Flooded, maintenance free flooded or AGM type.
Hi boscoe,
I got the regulators and will put them on this weekend. I was hoping I could ask one more electrical question. Since I have the twin 40hp engines, I have 2 batteries...one for each motor. Is it possible to run both motors off of one battery or would the double charging mess the battery or the charging system up?
Hi boscoe,
You can do what you suggest. Run both motors with but one battery connected. Unconventional but not impossible. Not sure why you would want to but...
With the motors running current is coming out of the regulators. The way that the regulators are designed prevents current from flowing back through the regulator to the motor.
I don't plan on it, but was more curious as to if it could be done. I now know that if I had a battery that died on me, that I could add the other motor leads to the one battery to get both motors to work...to get me home.
Brad
