"First, I might say, my first
"First, I might say, my first tunnel boat was 17' powered by outboard with speed around 55mph which was too squirly so I went to the longer boat which tried to kill me at 70+, end of my tunnel boat life.
The high performance tunnel boat as I viewed them on show room floor were nothing but sport versions of hydroplanes. They have a "sponson" or planing surface on each side of the boat which forms a single tunnel down the center. I am assuming this is the "cowel" you are refering to? On plane, the boat rides on the lower or bottom of "sponson" and somewhat supported by the thrust of the prop at the center stern. However there are large cruisers with the same type of design but not intended for the insane speeds. As for many hull designs and water tight integerity, I do not know.
As for water tightness, I have a hard time figuring why anything in the water would be intended to leak because what leaks out in exhaust gases, can leak in as pure H2O.
As I said there are many designs out there and who knows, maybe one is intended not to be water tight, I've seen some wierd stuff over the years. As for a double tunnel, I have not seen but can easily emagine the configuration.
A very basic tunnel boat is a pontoon boat and a very large tunnel boat could be a cat, its all in the eye of the beholder and new termonology. Again, I have no clue on your design so again I bow-out.
Pausing to take a breath.........
Are you sure that you have not restricted your exhaust in some manner? Your symptoms indicate it. Or they filling up with water and depending on size of boat, you are trying to plane a extra half ton of water?
Sorry if Im no help"
