"ok so here is the deal i have
"ok so here is the deal i have an 86 3.0 omc on a 17 foot sea ray seville not the biggest boat in the world and other bigger boats are getting up to 40 with this motor but i barely break 30 and feel like i have not pulling power at all. also the boat kinda has a dead spot every now and then and once i get the throttle past about half way i dont feel any more power out of it from half way to full open.
here is what i have done.
head checked out ok.. new exhaust valve and new seals
new head gasket, exhaust gaskets and all the other s when doing a job like that, new thermostat as well
i put new impeller in it
new gas filters
rebuilt the carb have the air bleed screws about to turns out as recommended
it has an electronic spark that replaced the old points
the timing is set at 5 degrees BTDC
not sure if thats too much could find the exact timing for the motor
but when i get on the throttle the thing just has no power it takes in like two minutes and once it planes out then it slowly picks up speed
and i put a new prop for waterski to get more pull power.... 13 1/4 by 17
also put a fin on the back to help it plane
is it a timing issue im just really off on something to ceck for the carb any advice would be greatly apprecitated"
new gas filters
