diver_dave
Advanced Contributor
"James; You have high shear e
"James; You have high shear engines (older, like mine) and run cool. Note that today's automotive oils, including most synthetics, have less ZDDP than when crusader wrote your manual. The mineral vs synthetic is a non-factor with us, the factor is cam/lifter wear and the anti-wear additives. Today's auto oil is made for low shear engines, using roller cams and modern oil pumps. Our engines don't have those. ZDDP levels have reduced considerably with SM rated oils. You may find diesel rated oil with high levels of ZDDP, but you will also get very high detergent levels, not a huge issue, but not needed either for a gas engine. Boiling off all this data, I run a conventional SM rated straight 40 oil with a bottle and 1/2 of ZDDPlus on a 50 hour schedule. I would think for you in the PNW, a staight 30 is better. Again, a synthetic won't hurt, but you really need to know the ZDDP content. If the oil is SM rated, it is very likely a low ZDDP content. You can find non-SAE rated oils out there that are made for things like V twin motorcycles, antique cars, etc that MAY have high ZDDP levels. You can do your own cost analysis on those solutions."
