troubleshooting help after opening VST
saltlicker
Hi all,
I have a 2004 225hp 2 stroke DFI, SN 0T875019. My boat was bogging down when getting up to 3500 RPMS I had taken it out maybe 10 times before it started happening. I opened the VST to change fuel filter and fuel pump. I also changed oil lines. Since I closed up the VST, it will turn over but not start. Im getting 90 PSI from fuel side but oil 30 PSI from air side. I assumed that the issue would be related to the VST since that is the only thing I touched but im not seeing any reason why the air compressor is only getting 30 PSI. I also did not disconnect battery. Could it be as simple as a fuse?
