Hello,
Serial Number 1B948812Model Number 1F90413ED
I've read quite a bit here and what folks have shared has been very helpful. I replaced a faulty float switch in my FSM based on troubleshooting steps provided here, so thank you! Unfortunately, it seems like I have run into problem after problem over the last year or so with this engine.
The first mechanic I took the boat to replaced the IAC and the boat DID idle better afterwards. Though it was still dying out after longer runs. This is when I took the FSM apart, tested and replaced the float switch. I also replaced the inline fuel filters. The boat ran better, but was losing power and stalling out. I was able to idle back to the dock. I ended up replacing the float switch with the Mercury part since I was worried the knockoff might be part of the problem (even though it tested fine). I took it out again and again it ran rough, but would idle decently. I took the boat to another mechanic that quickly diagnosed one of the inline filters as being defective. Supposedly an internal piece of the filter broke off and was clogging the fuel flow. Took the boat out again continued to have issues after running at high speed. Now after idling a while, the engine finally stopped even starting.
It did not appear that fuel was getting pulled into the FSM, though fuel was visible in the high-side inline fuel filter side and this side was under some pressure since it sprayed everywhere when I disconnected it to check it. Fuel seems to be flowing freely from the main tank, but there didn't appear to be much in the FSM when I removed it yesterday (though again, fuel was in the high pressure line). I ordered a new seal kit figuring it would make sense to replace it, but I am not sure where to go next. I do have vessel view, but it is not throwing any alarms related to the fuel system (it has on occasion when I repeatedly try to start it, thrown both a neutral switch error (110-Legacy) and an oil pressure (85-legacy), but these faults seem to clear on their own.
Apologies for the long post, but I am not sure where to go next. Was thinking of replacing the fuel lift pump, but I am not sure that is 100% logical. Also wondered if the pressure regulator could be preventing flow after fuel gets into the high side, like at some point, could a vacuum prevent the flow of any more fuel?
Thanks,
Alex
Thanks,
Alex
