FixMyMotor
1998 15HP 4-stroke has me pulling my hair out.
Previous symptoms:
Would run for a mile or two, then lose power a bit, then quit. If you wait a minute it will restart and you can go again. We actually used it this way for part of the year, but that changed after it refused to re-start like it had been doing.
Current symptom:
Now it will start in the morning and you can run it at the dock, pretty much as long as you want. It runs smooth, has power. If you turn it off, it will not restart that day. Not kidding. No matter if you run it for 5 seconds or 5 minutes if you turn it off it will not restart that day, even 4 hours later. It will restart perfectly tomorrow, though. It starts very easily. Once a day.
What we've checked:
New plugs
New plug wires
Fuel pump is good
Water pump/impeller is good
New Stator/Charge coil 2 years ago
Temp switch seems OK
Previous symptoms:
Current symptom:
What we've checked:
New plugs
New plug wires
Fuel pump is good
