C
chris nelson
Guest
"i have a 1965 johnson mq11c,
"i have a 1965 johnson mq11c, went fishing a few days ago, about 15 to 20 minutes of running the motor it started to cut out and sputter,on and off,thaught it might be the gas but that was fine. I changed the spark plugs today and it seemed to do about the same.could it be a coil problem? also after moving the garbage can with the water to run the motor in i noticed alot of water and oil mix draining from the bottom just above the prop. I dunno if anyone can help me out with this, sorry for such a long question.. Thanks chris..."
