chuckhanson
I decided to replace my gasoling filters yesterday. I picked possibly the best day of the year to do this job. The temperature index was 115 degrees at Pickwick lake. The project went very well on the port engine; the engine started and no leaks. Then I turned to the starboard engine. The installation went well but the fuel pump was pumping air only. I first focussed on air leaks on the suction side of the pump. Then I turned to air sucking back through the generator which shares the same line from the starboard tank. Finally I looked to the improbable; the dip tube may have fallen off. I carry a piece of copper tubing for this purpose. I opened the gas fill cap and inserted the tubing. For some reason I pulled it back out and it had very little gasoline on it. I got my handy dandy measuring stick and found I only had 3" of fuel in the tank. In twenty-two years of boating with this boat, I have run out of fuel one time. It was on the port tank. It ran out at 2". In that case I was feeding both engines off one tank. I ran out on one tank with a full tank on the other side.
In the future, I will check my fuel level as a first step in troubleshooting a fuel supply problem and avoid four hours of troubleshooting in melting heat. On the good side, I lost 3 pounds yesterday. I will probably find them today. Another good thing is that the last time on the boat, I went for a three hour cruise. I got back to the slip just as I was running out of gasoline and didn't realize it. I was having more fun and burning more gasoline than I figured.
Chuck Hanson
Chuck Hanson
