JIMTMCDANIELS
Hi mates!
Any expertise greatly appreciated here:
I am use to 4 cycle car engines.
My first boat, an always freshwater glass 1982 Sprite 17" seahawk bowrider? has a 1980 Evinrude V4 140 Crossflow outboard, 1200 hours on the clock and previous owner said it ran ok before he parked it 6 years ago.
I put in a 12V new deep cycle battery fully charged and a new fuel pump(that shows no indication of leaking into the cylinder that pulse powers it).
With water muffs, it still does not idle well or for too long, warming up does not seem to make much of a difference, I need to fix this before going on the water.
The key push in primer seems to be working fine to help start it when needed.
With the warm up lever up, the rpm's hold fairly study around 2,000.
When the warm up lever is finally brought down, with the rpm's then around 700, the rpm needle surges up and down by about 500 rpm's, Although for a short period it did idle without surging..
While idling, I have disconnected and reconnected each cylinder spark plug wire and found that the rpm does not seem to be effected when removing either of the bottom spark plug wires, but either of the top cylinder wires removal kills the engine..
Also I find while idling, that there is low or no suction noticed when placing my hand over the bottom carburetor throat with the access cover removed, compared to the top carb throat and spraying carb cleaner into the bottom carb throat while idling does not have much effect.
I have replaced all the dried recirc system vacuum hoses and tested the 4 recirculation check valves using a syringe of rubbing alcohol as described in my repair manual and they test good, not allowing flow in but allowing flow out.
I have added an inline-see-through plastic bulb spark-test checker between the spark plug and the plug wire, to each of the spark plugs and they all show sparking while idling.
I have checked the compression on all 4 cylinders is 100psi and have removed and cleaned the water cooled exhaust plate with new gaskets, which only had some carbon buildup and viewed the piston tops and cylinder wall and rings are free and all looks great including still slightly visible factory cylinder cross hatch marks.
New thermostats and popetts and gaskets and short hoses installed.
I also removed the 2 carburetors and disassembled including jet orifice cover screws but did not remove orifices and found gas in the bowls, floats level, needle valves hold when mouth blowing through fuel line to and no carb gunk present and sprayed all holes with carb cleaner including low speed jets orifices and all seemed to spray through and I reassembled.
Visually inspected reeds with carbs removed, they appear good and I lightly touched them and they open with a oil sticky pop. I have ordered carb rebuild kits which include new needle valves.
I had removed all the spark plugs and turned the flywheel clock wise slowly with a wrench while holding up to my ear, a short hose inserted into the intake manifold throats and I find the top throats make a reed opening popping should but the bottom throats make no noise or a weak scratchy sound..
I don't notice much or any crankcase pressure resistance on the wrench while turning..
I have also replaced the spark plugs and water pump impeller and seals and changed the lower end oil and lower end top seals.
SO...advice please, seems to me from doing much reading that the bottom crankshaft seals may be bad/leaking-the problem?
I don't see much mention of these seals getting much focus in forums but I saw someone said they should be replaced every 5 years..
So I ordered the top/bottom seals kit (2 seals and 4 large O rings).
I see it said that the power head has to be removed for the bottom seal replacement.....does not sound like fun. and my manual does not go into detail on how to remove it.
But if there is no suction from the lower cylinders, how is the fuel pump being powered and if the lower crankshaft seal is bad, would this effect both lower cylinders or just one?
Seems I need to also remove the intake manifold and reed boxes and inspect them closer and replace the intake seal if it might be old or leaking, could cause no suction..
I have not checked adjusted the ignition timing sync as this requires to be on the water and assume that is still ok.
Any input is appreciated!
Thank-you for your time.
Jim
Jim
