Yesterday I launched my boat (1996 Crownline 182BR with 4.3 Merc). It started right up and we went over to a dock with no issues. Kids got in and we started out on the water. After running 3/4 throttle for 5 mins the motor started sounding weird, so I backed it off to neutral and took a look in the engine hatch. It was filled with water. I had put the plug in before launch, so I knew it wasn't a plug issue. I immediately turned around and headed back, but we were taking on quite a bit of water and the engine started smoking a bit. The kids were getting a little nervous, to say the least.
Once we go hooked up with a passerby that towed us in, I cut the engine and the bilge started to keep up and actually started to reduce the water level.
So now for the real question....what the heck is wrong? Last Fall, I winterized as I did the previous season....I borrowed a friend's winterizer kit, ran the engine for a minute with the antifreeze flowing through the muffs, then turned it off. That is all I did. As I read about this issue more today I realize that I probably didn't winterize it properly, but it is too late now to go back and undo it. What should I be checking first? Freeze plugs? (where are they?) burst cooling hose? What else?
Tomorrow I will run the engine in the driveway with the muffs and try to determine where the water is coming from. But after that, I pretty much have no clue. HELP!!!!
