Hello guys,
I'm new on this forum, and saw lot of great articles here, hope you can help me to.
The problem is related with power of trolling motors. I have catamaran type boat, with two 4m long and about 0.7m width pontoons. The weight of fully loaded boat with passengers is about 1500lbs. For this boat I use two 86lbs 24V motors. Maximum speed of boat measured with GPS was about 4.349598mph(7km/h) with total current draw about 80amp.
But I'm not sure how effective I'm using this motors. Because I read lot of articles about trolling motors and rule for choosing motors is same: 2 lbs of thrust for every 100lbs.
For example here:
https://www.trollingmotors.net/blogs/selection/86933703-trolling-motor-thrust-guide
is given same formula- 2 lbs of thrust for every 100lbs. So in my case 1500/100*2=30lbs. Even if I take 55lbs motor, this is far away from 2*86lbs. Also I know, that speed of the boat depends of rpm of motor and pitch of prop, not only lbs. Motors with different lbs can go in same speed.
So my questions:
1. how many lbs I need for my boat to achieve about 4mph?
2. If boat goes lets say 3 miles per hour with one 86lbs motor and uses for example 30A current. What happens if I turn on another identical 86lbs motor? Did total current must be 30A or 60A for same speed at same conditions?
sorry for english.
Greately thank you.
For example here:
So my questions:
sorry for english.
Greately thank you.
