Trim
forgiven
88 Evinrude All I get when try
88 Evinrude All I get when trying to go up or down is a click at the relays. Put new relays on & switch is good. I can straight wire it direct & it works great. What could be the problem?
"If you're straight wiring
"If you're straight wiring the PTT electric motor direct from the battery, I'd suspect one of the following.
1 - You have a dirty or loose connection leading from the battery to the Relay Box.
2 - You have a broken or faulty connection leading from the Relay Box to the PTT electric motor connector.
3 - An extreme amount of corrosion exists at the PTT electric motor connector.
Any of the above results in a voltage drop which will cause the PTT motor to malfunction."
