"I know this subject has been
"I know this subject has been addressed to some extent but I believe my problem is slightly different.
Info first.
1974 Fibreform recently updated from a 302 to a 351 marine rebuilt. Leg recently replaced with a approximately 1990 alpha 1also a rebuilt.
Ok, it started out with the leg not wanting to go down from the trailer position without a little help to get it started.Recently it has refused to go down at all and although the motor{pump} runs, it doesn`t seem to have any resistance , sort of like a starter that has a busted bendix and just spins freely. Now, if you hit the up buttons for a sec, quite often it will then go down. Well today it was in the down position and refused to go up, acting exactly the same as when it wouldn`t go down. Fluid level has been checked and is ok. Because the motor is working , not sure it would be electrical. Sort of acts like it has air in the system but was lead to believe these were selfbleeding?
One other note, I have had the boat for 3 years and the up button has never worked without also pushing the trailering button at the same time which I know isn`t right but have never gotten around to fixing! Do you think these two problems are related , and it may well be an electrical problem . For all I know they up and down may be both trying to operate at the same time,LOL!
Info first.
