My trim and tilt sometimes doesn't work in the up switch position. If I quickly hit the switch from down to up several times the trim will work in the up
position. Is this a relay assembly problem or something else? Any way to test if the relay assembly is the problem, without buying a new one? Any suggestions would be appreciated.
Thank you
William
Thank you
William
