I have a late model DF70 that t/ts fine from the control handle but not from the cowl. A quick prob shows no power to the switch at its plug. Power jumped to either side makes it tilt thru that harness and an ohmeter confirms the switch is fine. Sooooo, white wire with red stripe should feed power to cowl switch. I see a fuse for t/t but it's fine, and the control handle switch works fine. Trying to find a wiring diagram that will shed light on from whence comes the white/red wire for cowl t/t. Anyone got a diagram to consult? Not having any luck online so far. Thanks zz03
