Trim/tilt 115 Mariner 6
fanie
hey,still sitting with t/t problem,i put in new brushes and clean the motor,but nothing all it does is a click sound, when push down and up please help, here in South Africa i cant get a service kit for the motor or pump
please help still got problems,got power allover,saloniods ok amuture turns only clock wise please, also how do u bleed the pump, thank you in advance:confused:
you may have a bad connection of the wiring harness. unplug it clean & it out.Or a bad ground (earth). you bleed air from the system by raiseing the motor all the way up & hold for 2 sec. let it all the way down hold for 2 sec.repeat.Add fluid when the motor is rasied & locked
