"Discovered a problem with the
"Discovered a problem with the trim up function yesterday.Trim down works fine , trim up was working intermittently.If I press the button enough times eventually it will catch for a second.Took the cowl off and checked the sky blue/white wire{ up relay } and the snap plug is loose.I tried clamping down on the female end with pliers to tighten but apparently this is not the shapeable/bendable type metal connector.I'm thinking maybe the male end is just worn down? How do I re-connect this? Just cut the male end off and put a new one on? There's also a black insulating sleeve toward the end of the male connecter."
