Trim Solenoid, should it 'click' both ways?-Trim issues
marcus33
Ive been having an intermittent issue with my trim... it always goes up, but doesnt always go down.
i pulled out the solenoid today, and found one terminal extremely corroded.
I cleaned up the terminals and put it all back together. The Trim seems to be functioning correctly right now.. *although of course i forgot to test it before i was messing around with it...
Even though its working correctly, i noticed the solenoid only clicks when i attempt to move the trim in one direction.
Is this normal? or is that a sign the solenoid is on its way out?
(off an 85el77s)
thx
If only one (1) solenoid is used...............
The tilt/trim solenoid is functional "only" when in the "up" (blue wire) mode.
When in the down mode, voltage is applied directly to the electric motor via the "green" wire.
