Trim Pump res single screw 1998 260
tuna_man
1988 260 alpha one.
I need the part # for the plastic single screw bottle.
4 screw bottle arrived in the post, trying to work out who stuffed up.
I asked for a 883166a2, single screw. thanks Mark.
PS, Is there any way I can fit this bottle?
Re: Trim Pump res single screw
"PS, Is there any way I can fit this bottle?" Only w/a four screw valve body from a new pump.
18525A1--RESERVOIR
thanks guys
Quality wise, is there any difference between the ARCO ($35) and SIERRA ($44) bottles? Mark.
Not really ,but the trick is to use some type of spacer between the inside of the bowl and the mounting stud if you notice the bowl collapsing when you tighten the screw.This puts stress on the bowl and causes the cracking.A washer or two will prevent this from happening when you snug up the mounting screw
