Bigfoot1979
First post here! Anyway I have been working almost a year on my 1995 Celebrity 190BR 4.3 Merc, I rebuilt the engine and outdrive, anyway I put the outdrive on last night and went through the procedure of adjusting my trim sender and trim limit senders, I bought brand new Sierra senders, I placed the outdrive all the way down installed the senders and adjusted the gauge sender till the needle was buried down (not very much movement flicks down or all the way up!?) went to set the trim limit and when i turn the sender it does not adjust the cylinders out?? I have tried and re-tried several times and I am at my wits end I have pulled them off and made sure the little marks are lined up when I installed them and they are correct, what else could I be missing!?? I can trim the outdrive up and down perfect it just never stops??? Could the trim limit switch be bad? anyway to test it? I have a Mercruiser manual but did not see anything else pertaining to testing the actual sender. I would be grateful for any help!! Thanks, Dave
