Hello all. I have used the search function as well as searched through the internet and found a lot of useful information. I still have not solved my problem, and am hoping someone here might have some suggestions.
I just bought an old used boat that came with a Mercruiser 305 5.0 liter. I am unsure of the year, but the boat is an 84 so I'm guessing the engine is close to that.
Since we got it, it overheats under load. Idle is perfectly fine, but when I get it up on plane, the temp quickly rises to the red. I know people are going to probably ask exact temp numbers, sorry I dont have that yet. Here's what we've done and where we're at:
New impeller, and all components are good
New manifold and elbows
acid flushed engine (friend did it, I wasnt there... so dont exactly know how good it was)
new water pump.
Thermostat is checked and good (ran without it and same problem)
Pulled the hoses going into the manifolds while under load and they seem to have good flow. Right side has less, but still looks ok.
Pulled hot hoses off from thermostat housing and both right and left side seem to be flowing good...
Any ideas as to where I can check next? My friend seems to think that we may have a blockage somewhere in the block. Any ideas on maybe a way to check this theory or maybe there's a way to break corrosion off the water jackets? I'm trying to avoid pulling the engine because I dont have a trailer... getting the boat out of the water, on a trailer, and pulling the engine will be one hell of a feat.
Thanks so much for the help.
Jason
new water pump.
Jason
