Transome%3d14 shaft%3d26 will it work
B
brinwood
Guest
Just picked up a creampuff ESK
Just picked up a creampuff ESKA 7 hp. Will it be too long on the back of my jonboat? The motor is 26" from the transom mount to bottom of skeg.
My transom is 14".
"Brinwood, You need to measur
"Brinwood, You need to measure from the transom mount to the antiventilation plate. That is the "true" shaft length. If it is 14-15" it is the correct one for you. If it is longer, it is likely the motor was intended to be a sailboat aux. powerplant."
