hi all. i have a fiberglass boat and the transom is in need of repair. this spring i did a fast fix with hydrolic cement i took a lot of the rotted plywood out between the fiberglass and pored cement in it to make it some what solid. i then reinforced with two 1/4 in plate aluminum and through bolted them. it seemed to work out ok but it really is not the fix i want. i took off my motor and took off the 1/4 in plates .i allso cleaned out the cement. there is sill alot of rot to be cleaned out.after i clean it out to were it seems solid i was wondering the best and strongest fix. the two back corners are my main concern. will a epoxy resien bond to the corners and be strong. i plan on using 1/4 in plate again but this time i am going to fab a pice that covers the back transom from corner to corner vs just were the motor is as this was a fast fix to get on the water. i am putting a 60 hp on this 1973 14 ft columbian fiberglass. so the motor is a little over rated . so i need a good strong fix as i will be pulling tubes next summer. any feedback will help thank you.
