Transom Bracket help
boatingfun1
Hellol found this while i repalced the bearing. can this be seals with something?
So you want to seal that cracked / blown out area.-----Try JB weld.-----But I think a fresh water used assembly is a better option.
Ayuh,..... I'm with racer,..... Epoxy might slow it down for awhile, but a clean replacement housing is the true cure,.....
