topgun3690
Having an issue at high rpms, cutting out near WOT.....initially thought it might be a fuel starvation problem. Decided to do the old JerryJerry starting fluid test around the intake side......sure enough when I sprayed near the bottom port cover it almost died, did it 3 or 4 times, same result. So I reckon she is sucking air. Should I go ahead and replace all 3 port cover gaskets or just the bottom one which seems to be the problem? Ordered 3 gaskets anyway, along with fuel diaphragm and gasket.
