TRahe 9.9 1996 hp
Trahe
My just-acquired '96 Johnson 9.9hp outboard does not put out water from the upper p-hole and I am leery of running it.
Do I need a new water pump?
Re: TRahe
Running in the water or in a trash can with the water a couple inches above the joint where the lower unit bolts up to the long exhaust housing (water pump area), poke a single strand wire up the water telltale fitting to clean it out. They do get clogged from time to time. Let us know what you find.
Re: TRahe
The wee hole in the fitting often plugs up------------remove it from the block and blow the hose out.--------------If you have just bought this motor, and you do not know the age of the impeller then it is almost a must to install a new one.-----------------Your motor likely does not have a system that will shut the motor off in case of overheat.---------------If the impeller fails you will like cause major damage.--------------Install a new impeller every 3 years or so.
Re: TRahe
Thanks, joereeves, I think I probably need a new impeller and will let you know if that does the job.
TR
