Arug.....I give up and must ask for help
I have a 1985 25hp 2 stroke Johnson that is not hitting/not working on the top cylinder
Checked:/completed
92lbs compression both cylinders
Nice blue spark both cylinders
Tried moving exciter wire and high tension spark wire from bottom cylinder to top. (Just to double check the coils) no change
Carberurator cleaned and rebuilt
Tried taping wood dowel on power head in area of reed valves
New spark plugs. Top plug (new) seems dry, not covered with oil and gas
What the engine will do is run on the bottom cylinder only
And I am out of ideas, engine should have fuel, spark, compression, So why has the top cylinder dropped out?
Any one with any ideas?
Checked:/completed
