Hi Guys,
Ricardo and El you can sit this one out if you want ; You've already given me too much great info and you guys probabally need a well deserved break. I'm wondering if there might be a tool that would make pulling the PDS shaft aft and out easier. I have full access to a well equipped machine shop and can probably make something up if need be. An industrial style drill chuck threaded 5/16 18 on the back side to take a slide hammer adaptor comes to mind as will as taking some pipe stock to fit tightly over the PDS, cutting it in half length wise the length of the PDS (creating A 1/16 in. slit) and adding ears with bolts in them to clamp onto the shaft, then welding a plate across the back of the pipe and threading it for a slide puller adaptor. I'm also thinking about drilling and tapping the end of the PDS shaft so I can thread a 5/16 bolt into it and then slide hammering it out (I really think the shaft is too hard to accomplish this). Also thinking about taking some flat jawed vise grips ( which currently slip off the shaft when hooked to the slide hammer) and cutting the teeth on the jaws in the opposite direction so they can get a better grip on the shaft. All advice is appreciated. If I can come up with something I'll make the tool and supply the blueprints or the tool to forum members.
Thanks Again,
Jon Allen
Thanks Again,
Jon Allen
