After installing a new rectifier on my 1987 48ESL I fired it up & checked the voltage output. At idle it is bbetween 12.9 & 13.1. I throttled up and it started to climb. When it got to 15 volts I throttled back to i idle and shut it off. Doing this in the yard on the hose. Battery reads 12 volts with nothing connected but has been sitting for a month in the shed. Is this normal? Can I run it in the water or will this over charge the battery and cause problems?
