"Guy I’m very frustrated, I be
"Guy I’m very frustrated, I been out to sea three time this year and had no issues with my 90-92 200 HP Johnson (as many of you might have read my posts before I don’t know what year model my motor is as the powerhead was changed before I bought the motor), but what is killing me is that when I’m trolling at about 1600 RPMs (or 7-8 miles MPHs) the motor smokes a lot, the main problem is the smell of raw half burned oil, other than that the motor runs good, I usually cruise at about 3200 RPMs at around 23 MPHs, I have tried rebuilding the carbs and all, but the smoke will not go away, at high speeds it does not smokes just at low speeds or low RPMs, I been thinking about just lowering the amount of oil in the mix for fuel to be used for trolling, probably not the right answer to my on going problem and I know I have an issue with the motor but I can’t pinpoint what the problem is, the tech says that 2 strokers smoke and I should just “live with it” as my motor starts good and runs good… any ideas recommendations???"
