Too much oil
R
rickvandyne
Guest
I have a 200hp evinrude and it
I have a 200hp evinrude and it is smoking at low idle..Runs fine at high speed...It is using 2x the oil..Do I need to replace the entire fuel pump assembly?
"Do I need to replace the
"Do I need to replace the entire fuel pump assembly?"
The short answer is: probably not. An air leak in the fuel line between the fuel tank and the VRO pump is far more likely than a bad VRO pump.
A 2 stroke should smoke at idl
A 2 stroke should smoke at idle.And how did you determine the 2X oil?
I do seem to have trouble keep
I do seem to have trouble keeping the fuel primer bulb up..If I sit for a while fishing (4Hours) I have to pump it up..
The oil comsumption was based on usually 2 quarts for 1/4 tank..I added 5 quarts this trip..
Checked the plugs..Not fouled.. Oil laying in carbs..
Heavy smoke at low idle...
